livingstone
Me acabo de enterar de que se fabricó una G/S de 650.
¿Se vendió en España?
Aquí pone que se fabricaron 1727 unidades.
Por cierto, en esta web hablan de todas las GS:
http://www.allroad-mc.com/bmwr1150gs/
Date 1987 - 1992
Number sold 1.727
Price 9.450,- DM
Engine
Type four-stroke, two-cylinder, horizontally-opposed "Boxer" engine, air-cooled
Bore/stroke 82 x 61,5 mm
Cubic capacity 649,6 cm3
Max power 27 PS (20kW) at 5500 rpm
Max torque 43 Nm at 3500 rpm
Compression ratio 8,4 : 1
Valves per cylinder 2
Valve control ohv, using push rod and rocker arm
Carburation system 2 constant depression carburettors Bing V 64/32/317 - 318
Engine lubrication wet sump
Power transmission
Clutch dry single plate, with lever-action diaphragm spring
Number of gears 5
Gear selection dog-type gearbox (ratchet foot lever)
Gear ratios 4,4 / 2,86 / 2,07 / 1,67 / 1,50 :1
Rear wheel ratio 1 : 3,44
Bevel/crown wheel 9 : 31 teeth
Electrical system
Alternator Bosch 280 W
Ignition Contact-free electronic ignition (Bosch)
Starter Bosch 0,7 kW
Spark plugs W 7 DC / Beru 14 - 7 DU / Champion N 9 YC
Suspension
Type of frame double-loop tubular frame with bolt-on rear section
Front suspension telescopic fork with hydraulic shock absorber
Rear suspension BMW Monolever - swinging arm
Spring travel 200 / 170 mm
Rims front 1,85 x 21 WM
Rims rear 2,50 x 18 WM
Tyres front 3,00 - 21 48 R
Tyres rear 4,00 - 18 64 R
Brakes front single disc brake Ø 260 mm
Brakes rear Simplex drum brake Ø 200 mm
Dimensions and weights
Length x width x height 2230 x 820 x 1150 mm
Wheel base 1465 mm
Ground clearance 218 mm
Tank capacity 19,5 l
Unladen weight, full tank 198 kg
Max permissible weight 398 kg
Fuel consumption 5,0 l / 100 km (at constant 90 km/h)
Acceleration 0 - 100 km/h 9,4 s
Top speed 146 km/h
Back to index
Date 1987 - 1992
Number sold 1.727
Price 9.450,- DM
Engine
Power transmission
Number of gears 5
Electrical system
Suspension
Wheel base 1465 mm
Top speed 146 km/h
Back to index
